Does the PFM twin turbo kit need specific exhaust manifolds, meaning that on the manifolds themselves one is longer than the other to make the turbos the same length to hook up carb adapter? Are the banks the same?
a lot of the exhaust logs are staggered already to compensate for the head configuration maybe some of the old logs were not cant tell you that.i just pulled a set of hardens off the shelf to see the actual measurements against an original gale banks set very close .close enough that your hose would make up the differance.just make sure you ask if the manifolds are even or if one is longer and you are good to go
A forum community dedicated to performance boat owners and enthusiasts. Come join the discussion about offshore racing, performance, modifications, builds, classifieds, troubleshooting, maintenance, and more!
