1 - 7 of 7 Posts
Am looking for some detailed pictures of the linkage when running dual carbs on a B&M 250...I have Enderle linkage but need to fab something to mount the throttle cable to the pull down arm on the carbs...Normally would bolt to the blower studs..but no blower studs on a 250...Surely somebody can help me out with some pictures...Can post here or send direct which would be [email protected]
No Sandbar To Far
Not a 250 blower but this is one way of doing it.
Thanks Sanger Rat..I have the linkage for the carbs...just looking for the hook up for the throttle cable to the pull down on the carb linkage...Height is different and no blower studs to bolt to...Will have to fabricate something
This is the best picture I can find right now, but you can get the idea, I believe. This is on my B&M 420. I do not know if the back case is the same on the 250. I hope it helps.
You can see the bracket on the back edge of the blower. Mine goes to a bellcrank, and up to the linkage.
1 - 7 of 7 Posts
