1 - 20 of 41 Posts
I dropped a valve and put a hole in the piston. It was a .30 454 I ahve no idea what these pistons were. I was hoping maybe someone might know who made these. The only markings on the pistons is the bottom, where the number 252-97 is stampted. Any help as to who made these would be appreciated.
Gone
You need to clean one of them up...and take a picture. Clean the top real good as there may be a number.
I don't think the other number you found will do much good.
When I had the motor apart last time, there were no makings on the top of the pistons. Those numbers are the only markings to be found.
If it's a cast piston I'd take it to a GOOD machine shop if you cant find any numbers on the top of the piston, they might be able to identify it or even have one in stock.
No, It is a dome. I just have a pic os the sies and the tore up top. I'll Post those up for you.
Looks like a TRW to me but thats a guess, there should be some #'s on the top. I have a set in the garage and they look really close.
Appears to be a TRW/Speed-Pro forging. The number on the underside is a forging number and not a part number. Speed-Pro has the part number stamped [early] and etched [late] on the top of the piston and should look like "L XXXX-F .0X0" if oversize. If someone massaged the tops of the pistons the numbers more than likely will be ground off.
1 - 20 of 41 Posts
