Will a manual Place Diverter control work with my berk jet? I don't see why it wouldnt. And will i have to replace my current line with place diverters line? THANKS
Are you asking if the Place manual controller with work with a JetoVater? if so yes and whether it will need a different cable (43C or BC) depends on what type control you currently have (manual or electric) TomWill a manual Place Diverter control work with my berk jet? I don't see why it wouldnt. And will i have to replace my current line with place diverters line? THANKS
That Trimetric controller and the Place unit both use the "clamp and flat type" 43"C" connection on the controller end, The Place controller will use a Heim joint at the controller pivot but otherwize your golden ..What i'm hoping will work is i can just hook a manual place diverter control to my current line. My concern is disconnecting the cable, don't want to break anything.
Is this a 78 bubble deck Eliminator? If so my Buddy has the same Thing.What i'm hoping will work is i can just hook a manual place diverter control to my current line. My concern is disconnecting the cable, don't want to break anything.
The leverage factor is diffenerent , the Older Trimetric Cav plate controllers have nearly a 3/4 inch difference from lever fulrum point to lower pivot the lack of leverage makes for more difficult action , especially underway The levearge, and "throw" need to be proportionate and relative to the lever at the opposite end. I have a similar controller on my personal boat that works fineIt's a 78 infinity. The trimetric is really hard to move, I have to be almost stopped to move it. This past summer the one tooth broke and part of the handle broke.
