1 - 5 of 5 Posts
Were to make hole in transome for place diverter cable i am running a manuel place diverter
Personally, I try to drill as few holes as possible in my boat, so with that said, I would suggest you try to run the cable through your Transom Adapter for a couple reasons. The first reason is mentioned above, the other two are that if it's a Berkeley, it's probably already got a hole it for a cable run thru and the other reason is that if you run thru the Transom Adapter there are more seal grommets readily available.
tintingsandiego
I also used hose barb fittings that I had to cut in half with a dremel and added blue hose to protect my cables...
Everyone does it different, My diverter cable is on the right thru the pump, my F/R is on the left side back transom, and below that is the speedo mount, the speedo isn't used but I don't want the ugly screw holes showing if I remove the plastic mount.
1 - 5 of 5 Posts
