I just picked up another boat with a 454 Mag MPI/Procharger set-up w/Aeromotive fuel sys. What plug should I use?
This brings up a good question, what is everyones preferred gap. I've always assumed that you would tighten up the gap with a blower.NGK GP Platinum P/N: YR5GP .040 gap
just my .02 cents
FastRat
John, Alot depends on what type of ignition system you are running. With Mags you run the gap at 18-20, with electronic systems (not sure because I don't run them) I would think you would run the gap around 38-40. Just my .02
Retired, gonna try SKYDIVING.Love the avatar Louisgrn
You and Richard racing this year or recovering?
used to run r42ts @ 35, 7-al2, crank trigger, locked @32*
16lbs. of boost, w/116 oct. fuel, never a problem.
Lets see, getting thrown under that dash at one circle race and then getting thrown out of the boat at another circle race WASN'T exciting enough for you?Retired, gonna try SKYDIVING.![]()
Speaking of avatar's.....You need to turn yours up-side down LOLLove the avatar Louisgrn
Jim
Like I would listen to you....I thought the Skydiving would get you going...![]()
I agree with Jim though you need to swap pullies....![]()
