1 - 7 of 7 Posts
Just bought a new house (built in '05), water pressure is low at the sinks and tubs inside, outside taps seem to be fine. It has a pressure reducing valve in the home, have tried both ways in and out, doesn't change anything. Have not yet replaced it, and I don't think it really needs it in the area I'm in. I have lived in the golf course area before and built my own homes, never had a problem with TOO much pressure.
When you first turn on the faucet, the water has good pressure, but then backs off to about 50%. Any real plumber help is greatly appreciated. I am soldering in a piece of copper in place of the PRV tonight. HELP!!!!!!!!:)grn
You can go to the Home Depot and buy a gauge that fits on the hose bib to check the pressure. You should be about 60-70 psi. But I would check with someone else to make sure. It could be the cartridges in the faucet that not allowing the water to come out fast. What type are they.
X2, Don't bypass it, replace it, the regulator stem sounds like its stuck in one spot, you can try to rebuild it, but so inexpensive I would say a waste of time....Try whacking it with a screwdriver handl to see if it will free up, but replace, not bypass (street pressure can fluctuate by 50-60 #)
GT :)hand
1 - 7 of 7 Posts
