1 - 20 of 71 Posts
I was using Met-ex today and the manifold and inter coller took 4 hours.
You need to be using Mex-i-Can... they work wonders!!! :D :D :D
The two mex-i cans were drinking all my beer:D
Then apparently you were using them wrong... :)sphss
Never Dull cuts through alot of the regular oxidation, but if it's bad you need to rouge it up and use a wool pad/wheel as suggested...
I found a company called 3D Products. They have real mild acid wash for mag wheels and a alumn polish called liquid metal. I use it on truck wheels all the time and I tried it on my alumn trim tank and battery boxes. It works great and took me a half hour to do all the alumn in the bilge. You can get the stuff online at 3dproducts.com.
Discussion Starter · #12 ·
Thats two for 3D products. My Matco tool guy is bringing me some acid tomorrow to try. Maybe the same stuff.
21 Daytona
A regular SOS steel wool pad used with water will cut most oxidation and not scratch it too bad.
I follow that up with jewelers rouge, then mothers
power metal.
if its really bad break out the 2000 sandpaper.
Because KAP said so...
Die Grinder, with buffing wheel...and white rouge, follow up with some flitz, simichrome, wenol, mothers, or that truck box polish from lowes it does work pretty good. Just don't use it with a high speed polisher, the chit goes everywhere:p
1 - 20 of 71 Posts
