Cas, the valve pictured on the left is also a Pollack? I assume its the three port listed on their website.
What are the extra wires on the plug for? The valve I took out only had two wires.
Yes, both of them are Pollaks and I'm not sure if this one is the same one listed. As far as the wires go, looking at the picture from the top down-
1. tank 2 sending unit
2. fuel gauge
3. tank 1 sending unit
4. to switch
5. to switch
The switch needs to be a DPDT and the part number on the selector valve is 42-154. No, I didn't do that by memory, I needed to find the instruction sheet :happy:
It is CG approved but I'm not sure Pollak makes this particular valve any longer. If you don't need it right away, just keep an eye on ebay as they pop up once in awhile. I think I have the old one around here that you can have for the price of shipping. It should hold you over until you find one of the bigger ones should you want to go that route.
