1 - 19 of 19 Posts
Questions:
1. 3/8" Aluminum for rails, front and rear plate ok?
2. Is it a good idea to just use big stringer washers on the outside of the stringers or should a plate be used? Ive seen the washers only on a few boats. It looks clean and lightweight, however I'm concerened about strength. My boat gets beat up on the river so Im a little concered. I thought that the flex might even cause the washers to dig into the stringer after time. Any input?
Thanks. How did the washers work out on these boats?
BTW- That upper pump brace lookes cool!
The washers work well if the integrity of the stringers is good , otherwize we use our backup plates , Thanks on the pump brace , Josh machined/milled that at the top to fit , it started life as a old school cast V-drive driveline support , we copied and modified it in Cad and will now produce it for E-Pump braces Tom
Discussion Starter #16
Cood deal Tom.
What size angle aluminum are you using on the rails?
Questions:
IMO, if you have 2" stringers you can use the washers. If you have 1" stringers, you need the plate for added support for the weight of the engine.
1 - 19 of 19 Posts
