What carb? Size, list number before anyone makes a recommendation.
yeh that is what i am looking for thanxPV is worth 6-8 jet sizes... if that's what you're asking.
S CP![]()
4165 seriesif i am running 64 jets with a 85 power valve on primes and 85 jets with a 65 power valve on seconds then what am i pullin with the power valves open??????????????
someone on the boards is helping me out, i am just askin for a census..
just for my knowledge???
thinking of plugging power valves????????????
You're welcome. If you're going to plug the power valves that thing will more than likey suck gas like crazy. Power valve = economy valve. What's the engine and how high do you rev it ? and what the reasoning to wanting to plug the PV ?yeh that is what i am looking for thanx
i would check the vacume.....8.5 is alotYou're welcome. If you're going to plug the power valves that thing will more than likey suck gas like crazy. Power valve = economy valve. What's the engine and how high do you rev it ? and what the reasoning to wanting to plug the PV ?
S CP![]()
X2!!! The only time you're in the secondaries on a jet is when it's dumped to the floor.PV on the secondary make no sense on a jet boat, should be plugged and jump up the secondary jets, imo.
Very true on the secondaries and I would think a 6.5 would be a better place to start on the primaries. RPM of engine and intake manifold type ? The 85's might be enough in the secondaries.PV on the secondary make no sense on a jet boat, should be plugged and jump up the secondary jets, imo.
An economy setting at cruise? Your kidding , right.. Keep the power valves in and set the carb up right, you will be fine. Jim :|errX2!!! The only time you're in the secondaries on a jet is when it's dumped to the floor.
However, if this boat is a cruiser and not a boat that runs at WOT at all times leave the primary power valve in. This will give you an "economy" setting for cruise.
I guess someone should define "cruise"An economy setting at cruise? Your kidding , right.. Keep the power valves in and set the carb up right, you will be fine. Jim :|err
it is a 455 olds with 10-1 compression, 280 comp cam, edlebrock performer intake, and a fresh set of "g" heads with a three way grind on them.You're welcome. If you're going to plug the power valves that thing will more than likey suck gas like crazy. Power valve = economy valve. What's the engine and how high do you rev it ? and what the reasoning to wanting to plug the PV ?
S CP![]()
I would agree with that statement.so it would be safe to say that the over all censous on this thread is, remove the pv on my secondaries, but continue to run one on my primes???????
That's what I was getting at. Our boat "cruises" at 3,900-4,000 out of the secondaries approx 50 mph. ( At least with the old 1,050 #9375 the new 1,200 carb might not be the same) Primary PV no secondary PV. Have pulled the PV out and up jetted and the thing sucked gas like I couldn't believe. Secondary PV's for anything that accelerates hard is questionable. Rear PV's un-load under hard acceleration and they don't make PV extensions but they do make jet extensions. Since your secondaries are only opening past 4,000 and it only rev's to 5,000 I'd pull the secondary PV out and see what happens.cruise has always been around 4000 rpms without touching the secondaries!! i hit WOT alot, but not for any lenght of time.
i have been slacking on putting the boat back together. trying not to melt down my heads again!! putting the final touches on it today, and taking it out for plug tests tomorrow!!To change the subject a little bit, when are we going to see you on the Snohomish river???hand
