Most automatic trans applications in v-drives do not use a torque converter, just a drive plate. There is enough slip and give with the prop in the water that a torque converter is not necessary.Can anyone recommend a torque converter that i should run in my power glide trans im putting in my v drive. Thanks
Is the fitting attached to the top gear cover for the tachometer?? How can I identify if there is a torque converter in PGLIDEMine is connected with a torque convertor eliminator bolted to the flexplate. No problems, running since 1978.
If you still have those could you send me a text I'm interested in doing a Powerglide in my boatI have two of these made by Hughes Performance Converters, PG25 17SP 3PD 2.5K HD, brand new been sitting in the garage for a couple years as they were for my dads boat.I would let them go for $200 a piece, located in Havasu.I believe the part # is 192282, that's what's on the boxes anyway.
7752308806. J.R.If you still have those could you send me a text I'm interested in doing a Powerglide in my boat
