1 - 17 of 17 Posts
Trying to get a reasonable baseline of how much a naturally aspraited 13.1 540c.i single dominator motor; fully cnc'd 325 darts w/ matched sniper intake. will make. Cam is a flat tappet (for now....).valve lift is .720. [email protected] 50 is 284* on a 108 lobe ctr. I know a mechanical roller would be superior; Just a ski motor deal. If...... and i say possibly if this combination makes 1.5 h.p per c.i i will be pleased. Would'nt mind hearing some of your opinions.;)
Thanks Bryan
Do you know the air flow of the heads ? With those #'s you can more than likely get within a few HP guess. ( +/- 10 hp) But off the top, your 1.5 HP # is probably close.
Sleeper CP
Big Inch Ford Lover :D
13 to 1 skiboat :D:D:D
who cnced the heads.like sleeper said,hard to get real close without flow#s if you have them anyone can run it thru a program and get real close with the correct info,other than that you are really pissing in the wind imo.
i have looked around but can not find #S for these heads and it will also depend on who cnced them.
imo that is one hell of a large flat tappet cam profile;)good luck,travis
yeah tom 13.1 ski boat me like that:)devil
360 CFM x 2 = 720 ....
360 x 2.1 = 756
If you can make 2.1 HP per CFM you're doing pretty damn good. The flat tappet won't allow max flow under the curve but the 13:1 will give it some serious pop.
My guess is, it will could make 740 Hp +/- 10 hp. More than likely 730 maybe 735. Just a wildass guess. But I think 1.5 HP/ cu. in is out with those flow #'s.
Sleeper CP :D
From the guy who plays with DD way too much, 700HP.
Way up at 6,500RPM or so.
i played with my dd to with some close flow#s i thought and came up with around 725 give or take.;)the flat tappet is killing it big time,imo.:)sphss
just like smokin said,6500 rpm
but in the real world who really knows these programs do get close but not on the money.good luck
B1 Racing
When all else fails blame the boat & set up not the motor! No seriously plans are to dyno as soon as i start to become a team player in another form of racing atleast with the donovan.:)hand
you should not have given up on that boat. you were close.
1 - 17 of 17 Posts
