Ducky Response
To start with we would like to say that while we have been producing Water Spot Removers longer than any other company in the industry it is within in our right to make tag line statement such as " tested agaianst the rest, still the best" especially when our testing proves it. Same holds true for any other company that feel their products are best. We all do it.
We would like to state that first of all not Ducky, not Hot sauce, not Boat candy, or any other product can remove all water spot and that's a fact we can all agree on.
Now we are not going to engage in attacks on competetors products ... it's not professional. Ducky Products, Inc. has been a respected company in the marine industry for over 20 years and have great relationships with many of our direct competitors. We would however like to address a few concerns and negative experiances a few of you have mentioned regarding Ducky "Original" Water Spot Remover.
When "Original" Ducky was developed it was not meant to be a water spot remover and wax product. It was designed to remove the hardest water spots just before they etch into surface using a formula strong enough to do the job but mild enough to not damage any surface. We succeeded in doing so and saved a lot of people a lot of money. As for residue or streaking left behind it should be noted that the instructions on the back of label say to use damp towel....we recommend doing a small section at a time and using wet towel, follow with soft dry towel.......no streaking, no water spots and still have wax on surface. That issue was one we always worked on, but hey....better than a ruined surface. "Original" Water Spot Remover should not be compared with any of the mentioned product or even Ducky Water Spot "Plus" it is a different product all together. Stronger with no wax. We will say to "Havasu 5150" and "Jake" that if you still have our "Original" in your garage take it with you. When you get to water spots that water spot remover with wax products cannot remove, hit it with "Original" Ducky....you will find instances were this will do the trick....and you will know what we are talking about. While developing Water Spot "Plus" that was our findings.
I hope this gives you a better understanding of our "Original" Ducky formula and how it is to be used.
Now as far a comparing our Water Spot "Plus" against others I think a product shoot out would be great....usually magazines will do this. I will say that the next time anyone from Ducky is in Havasu we will be happy to give sample, have a couple beers and do some testing with any of you. Feel free to contact us
www.duckyproducts.com
