Need to get some help with this ,some direction on how to set this up then I can play with it on the water, thanks.
May 13, 2017Need to get some help with this ,some direction on how to set this up then I can play with it on the water, thanks.
Timing at different rpms, I always have had the 6al plug and go but this one is a bit different trying to get the most out of the motor wanting to know a starting point on rpms and maybe someone has a setting that they use.May 13, 2017
Hello People
Slinger
What are you trying to control :shock:
Willis
just running the 6al 2 right out of the box no fancy mojo if this doesnt work its back to the 6al and Ill have to like it.are you using msd digital graphview? we run digital 7s, so not quite sure about the differences with a programmable 6al
May 14, 2017just running the 6al 2 right out of the box no fancy mojo if this doesnt work its back to the 6al and Ill have to like it.
fancy mojo? it's programmable, how is that fancy? not sure what you were expecting but it won't program itself. do you have the software downloaded to a laptop? do you have a 9pin serial port to usb cable? just power up the 6al2, connect the cable, open the msd software. the software is pretty easy to negotiate. if nothing else, you'll need to do that to get the rev limiter set where you want it.just running the 6al 2 right out of the box no fancy mojo if this doesnt work its back to the 6al and Ill have to like it.
Well cool that settles that,,, just running it out of the box no ATOMIC /BLACK POWER GRID/ or all the other MSD add ons they offer Thats what I was referring to NO Fancy crap And what I was expecting was the President of MSD to personally hook this up for me and set it so it would shoot roost everywhere while my eye lids are peeled back drinking a cold one,But that doesnt look like thats going to happen :grin:fancy mojo? it's programmable, how is that fancy? not sure what you were expecting but it won't program itself. do you have the software downloaded to a laptop? do you have a 9pin serial port to usb cable? just power up the 6al2, connect the cable, open the msd software. the software is pretty easy to negotiate. if nothing else, you'll need to do that to get the rev limiter set where you want it.
not sure what any of this has to do with the first question you asked. whether it's the 6al2, digital 7, grid, they all need to be programmed? not sure what you meant by "play with it on the water", unless you are carrying your laptop on the boat??Well cool that settles that,,, just running it out of the box no ATOMIC /BLACK POWER GRID/ or all the other MSD add ons they offer Thats what I was referring to NO Fancy crap And what I was expecting was the President of MSD to personally hook this up for me and set it so it would shoot roost everywhere while my eye lids are peeled back drinking a cold one,But that doesnt look like thats going to happen :grin:
