I had a 19' Schiada, ran 22 gears and 11 1/4 x 16 prop, turned 7000 + rpm. Its in the Orilla area I believe
I would be sure of the FE Hp prior to 1973 and past could be a 352- 427 CI. Thats 200 -425 HP. FE parst are hard to find and expensive.
If its 352 12 gears two blade 11 x 11 1/4 14 or 12 x 14 three blade about 4500 rpm possible 5000. Two blade will give you 5000 +
I have run 352,390,427 FE engines.
