so im about to order the stuff to do my exhaust and a local guy says i have to pull the motor to put the block off plate on, is this true........:mad:
Sure do I just pulled mine due to a leak. It will cost more money but you could put a silent choice or captains call on it and retain the y pipe
All the way or just slide it forward, was it a bitch.......
You could probably just slide it forward if you remove your back seat. You have to pull the outdrive then the four motor mount bolts and the wiring which most of it just unplugs. takes me about 2 hours to get it out and maybe four hours to put it back. Also remove the hatch don't try to work under it.
