1 - 13 of 13 Posts
Member
I've got a 21' 1996 Eliminator, 207 Skier, with a Dominator jet. I have 60 hrs on the Dominator pump, 30 hrs on the rebuilt stock 454 motor, with a 4 bbl Edelbrock carb. My max RPM's are 4200, and top speed is 43 mph. I have a place diverter and I have played around with it and all I can sqeeze out is 43 mph. The boat is in Bullhead City and I want a shop with a good reputation to check the engine/pump to see how I can get a little more top end. If I have to take it down to Havasu, no problem. Any help is appreciated.
u might want to check with Jim (Squirtin Thunder) on the boards here...he is located in BHC...he does good work & rebuilds alot of pumps :)
FastRat
With those numbers I would guess that you have about 330HP and an A impeller? Sounds like maybe a fuel problem, unless the pump was not setup right. With those numbers you should see about 50-55mph.
What size is the Edelbrock?
Maybe some else can give better advice?:)hand
Member
Discussion Starter · #4 ·
Thanks FastRat, I will look for Squrtin Thunder....
MAXXJETT, you are right, 330 HP, A impeller. I don't know the size of carb, only that it is a 4 bbl. I would be very happy with 50-55 mph.
Thanks for your help
Jet boats love fuel, I would say that you need about 750cfm carb. There is a good chance that the Edelbrock is only a 600cfm. You may want to run the numbers on the carb, to find out.
Angry American
here's the Edelbrock carb numbers along with what cfm they are-
1403 - 500 cfm
1404 - 500
1405 - 600
1406 - 600
1407 - 750
1409 - 600 Marine
1410 - 750 Marine
1411 - 750
1412 - 800
1413 - 800
Member
Discussion Starter · #9 ·
1403 - 500 cfm
1404 - 500
1405 - 600
1406 - 600
1407 - 750
1409 - 600 Marine
1410 - 750 Marine
1411 - 750
1412 - 800
1413 - 800
Thanks, this will help me!
JRPM/e-PerformanceMarine
I take calls 24/7. I can work around your schedule so we can check out the boat/engine and see what is going on and how we can fix any problems. Give me a call anytime.
BTW-Thank you everyone for the recommendation.
Thank you
Jim
JR Performance Motorsports
928-770-4394
1 - 13 of 13 Posts
