On a Berkeley style (mixed flow) pump...
Is there an "optimum" ratio of bowl pressure to intake pressure (example, something such as 10:1 ratio with 300PSI bowl pressure and 30PSI intake pressure...numbers thrown out at random simply for example purposes)?
Is there an "optimum" AMOUNT of bowl pressure and an "optimum" amount of intake pressure? Example would be once the loader and shoe are balanced so that you're getting equal pressure at the top and bottom of the intake, is there an actual amount of pressure you shoot for?
Is it better to increase flow while keeping the bowl and intake pressures the same?
