I have a few questions regarding some berk parts first off Intake #h-1784 does any one know what intake this is, also what would the major differences be between a 12ja and 12jg
Sit N' Spin
The intake on most pumps (except the E and F pumps which are the insert type similar to a Panther) is pretty much the same. The bowl is the main difference.
Angry American
The bowls are very similar and I think the major differences between the 2 is the pump shaft on the splined end of the A is longer than the G, the bearing caps are very different and I don't think you use a grease seal.
I'm just going by what I've seen in the past and have no experience with the A pump, sorry.
Discussion Starter · #5 ·
I am trying to make a decision if i should try to find a jg or just spend the time and make the ja work as far as i understand the pattern on the intake is the same between all of them correct
Cas is correct, The A intake is uniquley than the G , the A doesnt use a rear T' bearing seal and the pump shafts are different lengths , the A B and G bowls all look very similar externally the G is slightly different in the area surronding the impeller shroud . The A intakes have less "bevel" on the flange the mounts to the boat hull opening . The bearing caps are very different the A seals around the shaft behind the splines vs the later type which seal around the back of the D/L Tom
this is the front veiw of an A pump
