1 - 20 of 61 Posts
Who has a solution to this problem. I've asked else where and only got goofy answers. What is the secret to pushing on push-on hose to push-on fittings? I've used hot water, WD-40, silicon, dish soap and nothing seems to get the hose over the second ridge of the fitting.
jetboataholic
Here's your goofy answer from me!:D
Have you tried crisco!:D
But seriously I don't have a clue either. Seen others do it and they just push really really really hard. They look like they're about to have a hernia.
I've even tried teflon gun lube and that's suppose to be really slippery. It is but not for this.
here is a solution.....go to an fittings and stainless braided hose :D :D
its funny cause i was dealing with this today. if you use the single barb fittings, sometimes its not as bad to get them on and off. those multi-barbed ones really SUCK!
jetboataholic
You just gotta find a really big dude to push them on for you.:D
jetboataholic
jetboataholic
Do like your little smiley is doin' there!:D.........:)st
jetboataholic
jetboataholic
Clamp the fitting in a vice with some towels or rags and lube and push like hell. That is how I do it with both the brass and alum AN.
Or join the gym and in 2 years you can do it by hand without the vice assist. :p
Discussion Starter #16
Is this Brian? Yeah, Yeah, Yeah.... and Wheaties didn't work either! I'm about ready to trim down the barbs and go with clamps. It worked great on the water hoses. I'll get a photo up tomorrow sometime.
If I could figure out how to rig up the press (12 ton) I'd try that! :D
I take an old adapter and clamp it in the vice. Screw the hose end on to it. Put a little greese on the hose end and up inside the hose. Then just slide it down in one good shot all the way to the bottom. I don't know what hose you are using but the Parker Push Lok hose goes together real nice for me.
Discussion Starter #18
Hi Dave,
You know what I've got, I got everything from you. I tried it the way you say to and it moved my shop 3 inches off its foundation. LMAO!!!
I've even soaked the hose in boiling water for 15 minutes and can only get just over the second bump in the fitting and there it stops and goes no further. Dish soap, WD-40, silicon lube, oil, and nothing lets the hose slide all the way on.
Greg
Hi Greg, my friend that told me how he did his fittings, I didn't mention that he's been lifting weights for almost 20 years now. He's a real big dude. So break out your big :)violent44 and go to battle!
Discussion Starter #20
Well Rod, I'm too old to start that crap but, I wonder, if I run downtown here in Sacramento if I can get ARNOLD to push these on for me? :)sphss I wonder if he'd be back?
1 - 20 of 61 Posts
