Racing H&M FE oil cooler has been mounted but never run so can’t call it new but….dual oil filter for Un-Blown applications, adaptor block for mount to engine case, bag of parts o-rings by-pass valves bolts etc.
(Copper / bronze tube assembly looks dirty it’s not, I even had it dipped at a radiator shop nothing came off. lots of discoloration from welding heat.)
Also cooler end water caps so you can run the water in a loop with divider in bronze cap or run water straight through the cooler one pass. $475.00 plus the ride.
No low ballers.
ISO Edelbrock Victor intake or Blue Thunder single 4500.
Thanks for looking.
Mike
