Getting ready to start my winter project and just trying to get some direction on which way to go with this. Bought a 22 Daytona at the end of the summer and the motor went south. Wanted to rebuild it this winter anyways so no biggie. Motor was a stock Merc 300 hp 454. Not looking for anything huge on the new motor just want it to run pump gas and behave well around the docks. I believe the block is a 2 bolt main with cast crank 3/8 rods and peanut heads. My thoughts are that even if these parts are ok once it's broken down and inspected that I would be better off building on a stronger platform, 4 bolt/forged crank/7/16 rods and better heads. Any of these parts worth salvaging or should I just plan on replacing all of them? They worth anything or should I just throw them in the shit can? The way I see it the only parts worth salvaging are the seawater pump and oil pan but maybe I'm wrong. I have seen some short and long blocks for sale but the ones I have seen have had either 2 bolt mains or cast cranks and the motors I have built in the past that was a no no but then again those were putting out a lot more power. I would love to get some recommendations on cams from anyone that has experience with this hull or something similar. As I said before I'm not looking to go huge with the motor just want a big block with a good friendly cam and figure on putting a Dart manifold and a Holley on it and upgrading the distributor and ignition to MSD. Nothing fancy on heads just have them cleaned up and port matched as needed. I'm done rambling now. Thanks for any advice
