As Timm said, get large ovals, rectangles are way too big unless you plant to be spinning that 454 in the 7-grand ballpark, and the large ovals (like my 049's) are best served with a mild porting clean-up and the large valves mentioned above.
My 454 had no work done 2 winters ago but mild head port/valve replacement on it's original 049's.
Intake, cam, and exhaust had already been uprated, the heads were choking it.
Throttle response was always excelent, is now amazing, and 400RPM was gained against the same Aggressor B impeller pump build (as I said, not a thing changed but the heads).
I spin 5400 off the nitrous, idle at 850.
You should be able to find used stock ones fairly cheaply, not many hundreds for the pair.
