1 - 20 of 23 Posts
Member
I have two questions that I would like to get some feedback on. I did a search but didn't see anything that applied. First: Is it difficult to remove/replace a rub rail? What is required? I have a nice SS rub rail that's in good shape, but eventually I'd like to remove it to sand and paint . I was gonna cap it, but I don't think my boat has lines that would benifit from capping. Second: I have some 1/4" or so holes in the fiberglass that I'd like to fill. I have access to both sides of the holes. Can I use something like Duraglass for this? Or do I need to get into the whole resin process? Thanks
If your going to keep and reuse the rub rail, just drill out the rivets and save the rail. As for plugging the holes, there are e few ways to do it. Get some cabasill and mix it with resin and tape off the holes from the underside and then fill the holes and sand smooth for the paint or gell. If you get some orange gell, you could also mix the gell into the cabasill and then it would match the color thats there if your not wanting to paint / gell right away.
jetboataholic
Just did this tonight!
Took me like an hour, including the time it took to cut the wood plugs. The "fun" part will be all the sanding and filling.
....like warm apple pie
HJ, thats not how you cap a boat....and yes, that does look like it took you about an hour. There is ALOT more involved in capping a boat, as the above post says. Nice thread hijack! ;)
Member
Lookin' good HJ. You didn't want tunes out on the river? I had a bad ding in the dash which is right where I was gonna put the radio anyways....worked out well for me.
I guess I was trying to take the easy (cleaner) way out. Resins and epoxies just seem like such a pain in the ass. I was hoping a little duraglass filler would suffice......guess not. :(
jetboataholic
Read the first post again RaceFace!!!!!
This thread is about more than capping a boat!!!!!! Part 1 was already addressed. Part 2 is about filling 1/4" holes!!!!! I filled 8, 1/4" holes and 3, 1/2" holes tonight!!!!
Also it's hard to take more than an hour doing fiberglass stuff, it tends to harden up after about 15 or 20 minutes!!!! How long would it take you to do that? 4 hours????
And the pictures don't do it any justice, it will sand down very smooth, I am expecting to only need filler on some very small sections!!!!
I don't feel this is a thread hijack at all!!!!
You've always got something negative to say to me RaceFace!!!!:|err
Dude, take a pill (since you aren't old enough to drink), and a deep breath. :)sphss
I watch you on these boards all the time and myself and alot of other people have offered you ALOT of advice to try to help educate you on jets, jet boating, motors and all that go along with it. Some of the things you do and say on here scare alot of people here and its been mentioned before by several other people that they are glad they aren't going to be boating where you are.....purely for their safety.
Sticking up for a guy that runs glass fuel filters against others that know better and have more experience, your electrical mounted under your weep holes in the headers (several warned you, including myself), rubber line run too close to your pipes (warned again by others), throwing down a bunch of beers and wanting to 'flooring it' (warned by ALL on that one) and the latest...running your boat out of gas cans?? DUDE!! :|err
And now I see you on the HB threads throwing around your 'infinite boating wisdom' when you have never even been behind the wheel. I just laugh because HB sucks and you are just adding to the joke over there.
As I have said 3 different times (and others have said too), there are many people on here who know ALOT from experience and by trial and error.
Mellow out and take the advice and slow things down. We are all a 'family' here and we all want safe boaters out there in safe boats. Cutting corners isnt safe for you, your passengers, or any of us on the water with you. And acting like you know when you don't doesn't impress anyone....especially the guys that have been boating for a while.
Again, take a pill and roll with the jokes. We all bang on each other here. Its all good. :)devil
Member
Sooooooooo.........I should just use some resin then? ;)
I didnt address the capping, Just the hole filling in his deck.
To cap a boat is alot more typing then i really feel like doing.
Member
Trust me......it's alot more work than I want to do also.:D My boat doesn't have the cool lines that 'capping' works for. Mine kind of has a 90 degree angle from the middle of the boat all the way around the back.
jetboataholic
Let's clear some things up here!
1)I never stuck up for someone running glass fuel filters.:mad: I was told not to run my plastic fuel filter, and immediately removed it and put in a metal fuel/water separator. I just asked the reasoning behind not running glass filters. Now I know, so I will never try it! Even though I never intended to.
I stuck up for using stainless bolts on the intake grate. And got smashed on that one.:D Thanks guys, it's the only way to get it through my thick skull.
2)I didn't do my electrical. The guy that did do my wiring put it down there. I don't know shit about wiring and happily admit it. And it's hard to tell the guy that did it for me, for free, that I want it moved and all rerouted. But, I will try.
3)I don't remember being told that my water lines were too close to my headers. Can you please refresh my memory, by posting that up for me. But, like you said, "trial and error"! How do I know what too close is, until I melt one.
4)"throwing down a bunch of beers and wanting to 'flooring it'" This was the previous owners, not me!:|err (again like you said I'm not, "old enough to drink") And he ain't touching the boat when it gets in the water!
5)"running your boat out of gas cans" Also not my call, I'm more of a bystander when it comes to starting my boat. If my mechanics, who have been doing this for 30 years or so, say it's alright, then I just roll with it. Also, you guys never gave me a reason for not doing it (until tonight, thanks Some Kind Of Monster), if you don't give me a reason or tell about an experience you've had, then I am left to assume that you are being over cautious and slightly paranoid. Sorry, just how my brain operates, not trying to be a punk or anything. It just gets a little crazy in here, and I ask 1 simple question and get 10 completely different responses on how to do it, then I get smashed when I choose the cheaper, but still effective way of doing it. Ex. My Plumbing thread: I choose to not run a thermostat because there are boats that have run for 30 years without them and it worked back in the 70s, without all the fancy crap that is on some of these boats, but then I get all these people telling me to run a thermostat and posting pictures of their thermostat setups! That's not helpful to me.:|err
I don't even have an electric pump to drain my tanks, so I have to rely on someone else to supply the pump, and I have to do it on their schedule.
I don't think that any of my 7 HB posts make me sound anything like an expert or that I'm even trying. (I just wanted to see what all the bitching was about when HB went down.) All I did was voice my opinion on the new Bassett headers (can I not voice an opinion on how something looks? The thread had nothing to do with how they functioned, or anything technical like that), make a smart ass comment on anodized fittings, and voice my opinion about what type of headers to use (before he said that he had an engine cover, which was his stupid mistake on his part, thus his stupid question, that shouldn't have even been asked). http://www.hotboat.com/forums/search.php?searchid=2213601
My boat is probably more safe than any of theirs! Let's see, 800-1000hp vs my 320hp or so truck engine, nitrous and blowers vs. my N.A. slug, insane amounts of speed and crazy amounts of pump pressure vs. my stock turd. Now, who's boat sounds more safe, and who's sounds like the crazy guys boat, who only a true adrenaline junkie or racer would drive or ride in?
Been trying to mellow out, but then you post something like that, and it seems to have hit a nerve.:|err
Do your research a little better, before you post something like that next time. And I'm sure, with you, there will be a next time. Until then.:)hand
Also, I don't smoke. And it would be very stupid to smoke while working with resin.
Sorry about all of this TrynPas!!! I'm done, and feel much better!!!:) I just seem to have a hair trigger tonight and have a lot stored up, I guess.:)hand
Member
:mad::|err:|err.............
LOL.....No worries HJ. Who knew that a thread about 'rub rails' would rub you guys the wrong way. :D
TrynPas
come to my house... look how I did it. I will be fiberglassing tonight until 6 or so. I will pm you my #. Don't let people think fiberglassing is hard....
the SOME things to remember.
1.surface should be clear of paint and CLEAN!
2. Mix the resin right.
3. Remove air bubbles.
4. Remove excessive resin. but don't remove all of it.
5. Allow adequate time to dry.
6. I was also told you should not fiberglass in weather below 70. BUT WE don't have that prob.
This is my first job alone. I learned from an amazing teacher. (repaired boats for a living). now does fiberglass body parts for race cars. (mostly off road.)
Member
Discussion Starter #16
TrynPas
Good stuff......I would like to check it out in person. Called you earlier cause I was actually up in your area dropping something off for work. I'm sure I'll have plenty more opportunities.
A lot of people are intimidated over doing glass work. The main thing I hate about doing it is the mess! Acetone takes care of that though and whatever is left over on your hands, that orange hand soap pretty much cleans the rest of that off.
Member
Discussion Starter #18
..........As for plugging the holes, there are e few ways to do it. Get some cabasill and mix it with resin and tape off the holes from the underside and then fill the holes and sand smooth for the paint or gell.........
Is cabisill a type or brand of resin? The mess doesn't really scare me.....I guess, just wanted to take the easy way out. Before I fill the holes, how do I prep/clean them? Should I use a countersink or something to make a beveled hole? Seems like if I use a countersink (just a little) from both sides it would 'lock' the resin in and it could never pop out. :)bulb
Cabisill is fiberglass that is ground up and powderlike. To prep i would run a drill about the same size threw it. You could countersink it if you felt better about it but not a must. Mix the cabicill with the resin and catalist after your prep work and just push it into your hole. I have used a saringe (sp) To inject it into small holes. Just cut the tip off a bit to let the product come threw easy. Tape will work just fine on the bottom of the holes. You could also use a toothpick or something to that effect to put it in.Wait for it to kick abit and you can cut off what you dont want off the top with a razor blade to make flush with minimal sanding.
I have also mixed gell coat with it and have done the same thing to fix gouges in gell coat. You can level it out with clear scotch tape, let cure and then just colorsand and polish smooth.
My skills might be old school, but thats how I learned.
TRG fiberglass (Todd) is a pro at this stuff, and i have watched him do some amazing stuff. You could get ahold of him and pick his brain abit too.
Tim
1 - 20 of 23 Posts
