I have a suggestion that just might promote sales and help the customers also.
If Brand “X” Cam Company would make a complete set of cam shafts that had only one or two of the cylinders with the cam lobes on the cam so the customer could install this cam for mock-up to see if this would clear the pistons for his / her application.
These Trial cams could be rented out with a reimbursement IF the customer bought their cam choice from Brand “X” Cam Company. They could rent a selection in the range of profiles that they are considering. Surely they wouldn’t want to keep a cam with only one or two sets of lobs on it. The shaft only needs to be 1/4 length of a full shaft. A deposit that would be refunded would also insure the return of the Mock-Up cams.
I know I would rent some from you if this was an option.
What do you think ?
Boz
What do you think ?
Boz
