1 - 10 of 10 Posts
msd 3stage retard box. it retards 20 degrees out for the starter retard, plus has 3 more retards(i'm runnin a 2 stage nitrous dealio :)devil)
None, but I don't use a hefty blast of Nitrous.
i hope to run advance at 36-37, pull out 6 degrees for the 1st stage, then another 6 for the second. if my retards don't work right, shiat's gonna get baddddddd:|err:)st:)st:)st
retards
OK, I'll brace myself for all the responses. What is the best initial timing and how much retard for nitroius? probably going for about 300 shot.
565 ci Chevy. 11-1 comp, Brodix alum heads, single dominator.
Jerry
Jerry
on race gas only, i'd pull out 9-10 degrees if it were me. my nx booklet says pull out 2 degrees for every 50hp of nitrous but that's always been too much in my past experience.
does anybody here run more than 400hp of nitrous? how much timing is the motor getting? i've never ran as much nitrous as i will be this season. 300hp is the most i've sprayed and i ran 25 degrees on a 11 to 1 bbf460 with cast heads without detontion signs.
1 - 10 of 10 Posts
