1 - 13 of 13 Posts
I have all new stuff cable,place diverter,lever! And when I am under speed the bucket will start to drift down and cause steering and water coming in boat problems! How can I tighten it up so it wont move under speed? Has anyone had to solve this problem befor? WT
Coby
Coby
Have you got a photo of what you are talking about?
I dont have a pix. of the pump with me! Everything is free (loose) and it moves to freely! WT
Widetrack most fwd rev controllers use nyliners for smooth operation and also have a "wavy washer" to tension (often missing) The Wavy helps keep the handle tight, check it out ? if its not there call me i'll give you one . If the bucket is adjusted correctly (out of the path of the exit at WOT) shouldn't happen ! lets see a pic otherwise ! Tom
PS You could also consider a three position locking type handle
I will check this out tonight! Thanks for the info. WT:)devil
Coby
About 500' AGL
Coby
I had that problem and just switched to a shifter with a detent. Problem solved.
http://www.rexmar.com/page39.html
....like warm apple pie
Exactly. Mine would pop into neutral half way into plane. What a pisser! I bought a new reverse handle with a button on the handle so it would lock into 'drive' and 'reverse'. Problem solved.
Or just hang onto the handle until you are on plane and going. I did that for years....then got sick of it. ;)
1 - 13 of 13 Posts
