Well we started assembling the 466 back up motor for our Comp Jet boat. Installed the cam, everything was good. We measured the crank main journals and that came up perfect. So then we put the main bearings in and installed the crank, so far so good. Well I know I should have checked the rod journals when it was on the bench, but I took it for granted that they would be right. They are 2.486 and they should be 2.500 or 2.490 or even 2.480. This sucks !! What do you guys recommend I do ?
Thank you
Jim
Thank you
Jim
