That looks really good Mike, glad to see you stuff is getting back together. I have one thing for you to ponder though, you might want to give consideration. My K.B. looks very similar to your Rodeck including the stamped in torque values. As you did, I assembled it with ARP assembly lube on the main studs. For some reason afterwards I decided to call K.B. and ask them about it. They said those torque values were based on assembly with 30wt motor oil, and not assembly lube, and that it would be in my best interest to clean off the assembly lube, and retorque using motor oil. You may want to look into it, the friction between the two would be different, as well as the clamping force applied. Maybe it's not enough to worry about, I don't know, but if you were to redo it, now would be the time. Good Luck, Todd~
