1 - 13 of 13 Posts
I am trying to find some rub rail for an 18' Advantage bubble deck (18' Rogers Bonneville). It is the 5/8" wide with the flat back(no lip) and the rubber insert.
Does any one know of a source for this type of rub rail?
I have the blue ano. I removed from mine (18' advantage) years ago hangin around here if ya want it Hal. Have the rubber insert too though it's prolly shrunk some and a tad short now. be good to get it out of my way. not sure how to transport in it's formed shape though. lemme kno.
Hmmm! Man, Warren there is an Idea! That would be kinda awesome! You have all of it?
I have found the rail but they only have it in black and silver and it is in Cali, at Shoemakers shop.
I have my old rubber that just took out, when I took the rail off. Rex Marine has the rubber but no metal.
Let me see what I can figure out, with my old rail, about fitting it in the truck. There would be two, big, wide pieces, the front and the back.
Rubrails.com
It's been a while ago when I bought some but it was a good price and good service
Sent from my SM-G900R4 using Tapatalk
Yes that is exactly it, but Rex Marine is currently out of stock of that particular type. Mike says he will not get any more until late 2016 and I am not sure if he will be able to get the blue ano.
I talked to Advantage and they said that they could not get it. they said they had a very hard time finding any for the one that they recently built.
There is a guy that works for GS marine, that had acquired a lot of the rub rail when the manufacture went out of business and sells it on the side.
My Advantage is the same year(86) as yours and has pretty much the same graphics as yours, except in a blue fade.
Rubrails.com
Yea,. I have check them and just about every where else. They have something similar but it has a lip on the back and I need a flat back.
Anodize
Just my 2.0, but I would try to stay away for any anodize parts for boats, looks really cool at first but fades quickly. I actually formed/bent my rub rail, and before attaching I epoxy primed and painted, (any color you choose) and looked great for many years. Powder coating small parts are always an option too.:)Unsure:)Unsure Good example would be gauge and switch bezals.
Hal it won't be late 2016, spring 2016. I am trying go get enough pre-sold to order very soon, a mill run. Clear and Black are for sure. If I see enough demand for other colors I will run them too. Blue and red would be the likely first 2 candidates considered. Not too many people want gold any more. I also have lots of rubber insert for this and for BT1 size.
Yes Hal I have all of it, insert too. correct on the two big pieces. they're hanging in my shop out of the way. I'll pm you my contact info and you let me know if/how you would like to proceed. Glad it will go to a good home.
Mike, how can I go about ordering the rubber insert? can it be ordered through you web site? I may need the rubber insert, no matter what direction I go.
I have been trying to get blue rub rail for my 87 advantage for a year and a half. That's two orders mike how bout it? If I could just get new without the lip and find someone with a 12' oven to powder coat it. I never thought I wouldn't be able to get replacement rub rail until i removed mine and tossed it in the garbage.
Clear and black are in stock now. Will run some blue in not too distant future.
Please email me with any interest as I'm not on the forum a lot and may not see pms timely. [email protected]
1 - 13 of 13 Posts
