Just cut all the old hoses open lengthwise to see what they look like inside and none of them had any indication of pieces missing like shown in the picture at the top. They had some slight buildup, but no pitting or visible chunks missing. This concerns me as now it appears that the source of the rubber chunks was not the coolant hoses themselves after all.
The rubber had to have come from somewhere in the cooling tract, so here is the path it takes.
- Water is scooped up from under the boat and passes through the water pump. I already disassembled the water pump to see if the impeller was falling apart and it was totally fine.
- Next the water flows through a transmission cooler. The trans cooler is quite old and I have no idea what the construction of it looks like on the inside.
- From there, the water goes through the V-Drive, which, like trans cooler, I have no clue what the water routing looks like inside of it.
- Next the water passes through a T-Spliter and into the rear of each exhaust manifold. (Edelbrock M2)
- The water appears to make a 90 degree turn to come right out another fitting at the back of the exhaust manifolds and into the front of each cylinder bank. I'm not sure why the water takes this path instead of just going straight into the engine block, so if anyone knows please enlighten me.
- Next the water goes into the front of each cylinder bank and flows through the block.
- Water exits the block at the top through a T-Spliter and into the rear of each exhaust manifold to be blasted out the back of the boat.
If the issue isn't the coolant hoses themselves, then it has to be one of these other components. After replacing all the hoses I ran the boat with a garden hose attached in the driveway for about 10 minutes. 5 minutes of that time was spent at 3,000 - 3,500 rpm to try to build up some heat. Engine stayed at 120 degrees the entire time. When in the water and running, it usually operates at 160 degrees, so 120 is quite cool. This leads me to believe it may have something to do with the trans cooler or V-Drive as neither one is engaged in the driveway, but are when running it in the water; which is where it has been overheating.
Any ideas?
