gonna post this here for later info since this is the boost tech section
Borg Warner S400w/75mm compressor wheel 1.32 A/R exhaust
Turbo Specs:Compressor Wheel Inducer/Exducer 75mm x 100mm
Turbine Wheel Inducer/Exducer 96mm x 87mm
Turbine Outlet 5 Inch V-Band
Turbine Inlet T6 Divided
Turbine A/R - 1.32
Horsepower Rating 500-1050
Borg Warner S400 w/80mm upgrade compressor wheel 1.32 A/R exhaust. Standard cover
Turbo Specs:
Compressor Wheel Inducer/Exducer 80mm x 109mm
Turbine A/R - 1.32
Horsepower Rating 500-1300
Borg Warner S400w/88mm compressor wheel 1.32 A/R exhaust
Turbo Specs:
Compressor Wheel Inducer/Exducer 88mm x 118mm
Turbine A/R - 1.32
Horsepower Rating 550-1400+
anybody notice that the ex is the same between the 75 and 88mm?
put a 88mm wheel and housing on your s475 and have a 88mm
Turbine A/R - 1.32
Turbo Specs:
Turbine A/R - 1.32
Turbo Specs:
Turbine A/R - 1.32
