first i am new to forums so please help me out with any tips you may have.
I have a 73 18' Sanger super jet with 455 olds and Berkley jet. The 455 was rebuilt 5 years ago but only has 30 hours on it. It has a Holley dual inlet square bore with vacuum secondaries. aluminum intake. HEI ignition. mild cam with light lope but still great idle. 9.5 to 1 pistons. Berkeley wet logs.
The problem is that the boat will not rev over 3500 rpm but has more throttle. i can get 3900 when cold. Once i reach 3500, if i give it more throttle it bogs just a little to 3200 and stays there untill i back off. compression is good, plugs, wires good.
