1 - 20 of 30 Posts
cj812
i picked up this old liberty in az on thanx giving, i needed a new familly boat because the hondo was too small.
the Liberty was in pretty rough condition, but, i liked the way my hornet handled and the liberty has the same bottom. So i took the wife and kid out to Az to look at it. the first thing she did was sit in it and she liked the leg room, compaired to the t-deck hondo. So it was a go:)devil
heres some pix
we got it home and stripped it down to check out the stingers. they were in bad shape and needed to be replaced:mad:. So i looked up kenny at BK boat repair in bellflower, ca. took it to him and he said they needed to come out, oh well kinda figured that.
cj812
it took about 3 weeks to get them put in, i decided not to go with a new balsa floor because i saw what happend to the old one. here we are putting it back on the trailer.
woo-hoo, its home
cj812
it had the 1 inch stringers in it, but, beings how its a familly boat and im going to beat the snot out of it in rough water i decided to go with the bigger stronger stringers. more pics
i decided not put put any transome wood in because im not going to hang any thing off it. Kenny said it doesnt need it anyway
this is the motor out of the old Hondo, it was running 5200 rpm with a jacuzzi wj and 52mph
i started out thinking i would use the 4 point mounts but in mid stream decided to make a rail kit.
now i had 8 holes in my new stringers that i had to fix,:mad:
cj812
we started fabbing a rail kit. 6061 t-6
no water jet here, porta band and 4 inch grinder. kinda primative i know but its what we have.
rails cut and drilled
not petfect but still working on it
cj812
i have to give a big thanx to my pops, he's the one who makes the plates.
mounting blox from rex marine. looking better
still a little triming to do,
motors back out for paint, the can said ford blue, not baby blue. the wife liked it but i couldnt stand it.:)sphss
cj812
a little rattle can and whamo. i dont know how to do gel coat and summers coming fast. if it peels i'll just bust out another can:|err
tanks are cleaned up and back in
new helm and cables, the hole in the dash is too big for a pretty bezel so had to use the old one. as i upgrade later it is on the list of things to do.
the blue motor had to go;)
cj812
heres the sub floor, i dont know shit about wood and carpet, so a friend lent a hand in trade for some summer fun.
prepping the bildge for the herculiner,
its gas and oil resistant so i went with it.:)sphss
damn alternator hits the rail kit, so pops fabbed a new bracket
cj812
installed the motor and found out the balancer wouldnt clear the bulk head:)hammers so out came the saws all. i know i should have taken it back to bk, but summers coming fast. i deal with it this winter.
carpet is in
had to trim the rail for the battery box
some 3x4 angle for the box to sit on
running out of $$ so i used an old box for this summer
cj812
Discussion Starter #12
new steering wheel
last year out at the AVI the hondo with this motor sheard a dizzy pin and stopped running. its a long story but i had to replace the cam, when we went to prime the oil system for cam break in i had no oil pressure. the oil pump was locked up, so out came the motor (again) man im tired of this:)sphss this is what i found stuck in the oil pump
i have no idea where it came from, so i had another oil pump so we slapped it in and primed the system. 80lbs so i say screw it and roll the dice. we stuffed it back in the boat and broke the damn camshaft in. no problem yet (whew)
i had jim brock at cyclone speed and marine go through the pump, its an aluminum A-cut. No big power here so i'll be fine. the pump is pretty
cj812
Discussion Starter #14
a quick stop at sweet performance for some fittings to finish up the plumbing
the cam break in
http://youtube.com/watch?v=C_PiRXtDFDE
put the inner springs back in, i think it sounds great
http://youtube.com/watch?v=SCHQn_9Ptes
now on to the interior, its shot wood is all rotted. but the the rest will work for a couple of seasons whith some towels over it. so brad said he would help me do the wood since i dont know shit about it. thanx brad
not too bad for 30 year old foam
cj812
diverter, go fast pedel and header valve
pumps in, memorial weekend is coming up fast so i ran out of time to even clean the damn thing. (just want to get on the water with my familly)
motor is back out to get the break in shell rottella out and vr1 20/50 in
getting the new oil, man it was hot that weekend
we are ready for the lake YEE-HAW
i took it out to buena vista this weekend and it ran flawless. 30 gallons of fuel and two 230lbs guys it went 62.7mph. i think the tach is wrong but it said 5200rpm. this is one solid familly boat, and thats what i built it for. if i want to go fast i'll get in the race boat.
cj812
Discussion Starter #16
some pix from this weekend
the wife likes this one:)devil
when its cold and they dont want to get wet this is how you do it
looking back there are some things i would have changed, money and time permitting. I will upgrade as i go, at least i have a solid starting point.
thanx for looking
ralph
1 - 20 of 30 Posts
