1 - 18 of 18 Posts
not ******
whats your all's take on these for jets? possible.....not practical....no need because of the gate valve.....just looking for some input
jetboataholic
I've got a strainer. Not sure if it's a Sea Strainer or anything fancy like that or if it's even what you're talking about. But it looks like a modified air compressor dryer. And it supposedly works great and keeps lots of shit out of the engine. But I haven't run the boat since I bought it, so I don't know. Just telling you what I've been told. Hope this helps and good luck.
That's it mounted on the other side of the pump with the two hoses attached to it and says MSD on the front of it because I used a coil mount to attach it. Is that what you're talking about?
No dats uh nuttin lika fancy like a der Sea Strainer. Thems lokka lika der water seperator outs one of dem dang 1990 Kawasaki stand up skis.
Uhh der lokka lika uh der you sprayed der Rhino Liner and yer dang boat.
not ******
my brothers got one on his blown 22 donzi, and i see every offshore boat runs them pretty billet ones.....im just thinking about it because where i boat towards middle summer the hydrilla (i think thats how you spell it) gets pretty damn bad and with my old boat i have sucked up so much of that chit it would clog the pump and i would have to jump over board and pull out. i just always wondered how much chit actually makes it into the motor water passages......
jetboataholic
Can you clarify this. I'm not to good at reading German!:D
not ******
What is everyone's opinion on having a sea strainer with a 525?
Sorry posted in the other thread also didnt realize there was 2.
i thought the 525 efi's have a closed loop cooling system? why not make it a closed loop water system too? :D
Horsepower sells Engines
OK so lets wake this thread. can we hear from some suppliers on products. i not spending 500+ on a strainer but i need something that is affordable and fashionable.
They better have some pretty strong glass in them. Your pump puts out very hi pressure at wide open throttle.
dont care if you can see the screen i can check it, my requirements pretty, functional. if i can see it even better
This is mine, one for the block and one for the headers...WARNING...it's plastic cover will blow apart under high pressure.
My block never sees more then 11 psi > I've used this type for years and years and years!
And YES...it will stop sand!
Sea strainer if you have an intercooler. Otherwise not needed IMHO. But that HO is based on where I boat.
well i boat in a lake that is not blue and under the water you cant see 2 feet in front of you. OK that sight said max 150 psi, what is the max im going to see should i see, i have been running without a reg for 30 years. what should i regulate it down to if i go to a reg?
Hehe. Hey that's mine. Thanks.
T.J.
I know it is, I have just about all your pics saved, your boat is bitchin' and the fact that it's done in your garage makes it even more bitchin'
1 - 18 of 18 Posts
