1 - 17 of 17 Posts
BTC cardcarrying member
Discussion Starter #2
128 view's :)hand
i can't believe im the only one using one of these :(
im thinking the lip go's inside :hmmm:
Post up a pic. Are you putting a 2 piece seal crank in a 1 piece seal block?
Didnt see the link the first time. I have used them and dont remember. Call Chris Straub. he sells them for B&B
Some guy
I think you need to actually look at the block and the answer should be obvious. If the "lip" is about .030" it fits to the inside and will hold the thing square, as there is a tiny groove in the block and cap.
Some guy
I re-read your post, apparently a shop put it together. I actually went out and looked at a Gen 6 block that I have here to determine that there is a small groove inside the original rear main seal surface where the seal adapter goes prior to my first reply.
I just had the machine shop build my short block and when I install the crank bolts they hit the adp.
same everything
yes a 2pc seal in a 1pc block gen5
the motor is at the shop and im going there in the am
I think it was in be for and all worked fine now the bolts hit
The step goes to the inside. It helps lock the adapter in place.
Thanks :))THumbsUp :))THumbsUp
im going there in the am and have them flip it :) then all should work fine again :)
Is this true for the 5 and 6 blocks both?
Stefs makes 2 different adaptors for the 2 blocks.I know its not a Stefs, but do both Stefs adaptors have the lip? Is there a place for the lip in a 5 block?
Not sure about that. This is a Gen6 block. You can see the groove:
If the OP had the adapter in the block before, then I'd say it's in backwards now.
That's why I was questioning. The groove seems to be self explanatory.
I have always wondered the difference between the 5 and 6 Stefs adaptors.
There is also a groove in the main saddle and with what appears to be a threaded hole. #4 saddle appears to have 2. WTF:wink2:
There you have it again. It goes to the inside. :)
I don't recall the B&B having a lip.
:rolleyes::54:
Discussion Starter #16 (Edited)
Thanks all :)) :))THumbsUp:))THumbsUp
I went to the shop and the lip was on the outside :(
had them pull the main cap and the gen 5 block has the grove
anyone else having trouble when typing it keeps locking up
1 - 17 of 17 Posts
