When was the last time you changed your seal? I would replace your seal and repack it with grease, maybe upgrade to a double seal if you have enough room between your coupler/safety collar and your shaft log. Alot of people use J drains and have no problems, I personally use plugs because all it takes is a little piece of debris to get caught in the J drain and you will have water coming in. Get a good bilge pump. PM Dimarco21 I think he is the one who makes a really nice shaft seal/bearing in 1 inch and 1 1/8 inch.
