I have a tx-19 that is set back and the hand hole is all the way out so that I can remove it.I have seen some where it is set back and it is not far enough to remove the hand hole cover unless you remove the transom plates. How should it be? Also how do you fine tune the intake housing after you have the right shoue set up? Do you grind away the shoue till the conversion is smooth, that is what I would guess.
