Come On, Donkey! Show them the Bad Boy....as promised here is the picture of mine. Wasn't too hard to remove. Take your time make a cardboard template first then transfer to medal. Get it as tight as possible that way you will use less silicone to seal. How far is your set back? If your shoe plate is even with the transom you may need to go with a 2 piece due to the bottom corners wont seal without a S#@t load of silicone.
Sorry wont do it, at least that part. Not till the boats finished.....Come On, Donkey! Show them the Bad Boy....![]()
matt , i forget who did it but i saw pics where someone welded( might be able to epoxy) a piece in the intake holes. Basically a plate going front to rear that closed in the gap on the intake. might look into that. ill see if i can find the picsPerfect timing. My Daytona is a full setback. I am in the process of making new plates for mine. I was thinking a one piece plate would be nice. I have another issue though. My intake has a place that is machined out. This leaves a big gap. No way I can think of to fill that gap with a one piece transom adapter. Sorry for the thread jack.
Paper template
In this spot I placed a piece of 1x1 x 3 aluminum block. I had to shave it some to get it to fit, and then I drilled and tapped it so the intake adapter bolt would hold it in place. Silicone fills the void. Works well. I was thinking I might redo this part on mine with some jb weld, btw the way it is now works.matt , i forget who did it but i saw pics where someone welded( might be able to epoxy) a piece in the intake holes. Basically a plate going front to rear that closed in the gap on the intake. might look into that. ill see if i can find the pics
Good idea TJ. I think I like sandeggo's idea a little better.matt , i forget who did it but i saw pics where someone welded( might be able to epoxy) a piece in the intake holes. Basically a plate going front to rear that closed in the gap on the intake. might look into that. ill see if i can find the pics
Pretty sure that is what I am going to do. Just need to mock it up and see if it causes any other issues.Just make the plate a little longer in that part, then bend it back at 90* so it covers the hole.
what are you guys using to seal between the Transom and plate? I used a Sika product that lasted only a few years, maybe thats the norm?I copied a friends MPD transom plate View attachment 209474 View attachment 209498 View attachment 209482 View attachment 209490
100% clear silicone dap productwhat are you guys using to seal between the Transom and plate? I used a Sika product that lasted only a few years, maybe thats the norm?
