Some pics to help establish what I'm dealing with.
Thanks guys
Piece O cheese, mechanical shift with all the right junk on it...As stated before, check the oil in the lower....
First things first.
Disconnect the shift cable at the box on the back of the motor by removing the small cotter pin. Once that is done, start the motor on a flusher and attempt to shift it to forward and reverse. It should move quite easily with just your bare hand. (make sure the kids, dog, cat and wife are nowhere near the propeller when doing this)...
If it moves smoothly and goes into each perspective gear without drama, slowly start to move the shifter (engine still running) toward forward and note the sticker at what position it starts to engage (ratcheting sound from the drive). There are numbers to note on that sticker. Then do the same for reverse, note the number...Neutral will be right in the middle, so make any adjustments to the cable to make sure this is correct.
If the arm is difficult to move, the first thing to do is to pull the box all apart and inspect the pulleys and cable guide for issues.
Step two (with motor still running) press the little arm and v-notched actuator together actuating the interrupt micro switch, there is a little bitty button on the switch. The engine should shudder, fart, bitch, piss and moan with the button depressed but not die. This tests the interrupt box and the switch.
Step three would be to ensure the interrupt switch cancel switches are adjusted properly. They should be depressed when the arm is in full forward or reverse. Adjust as necessary with a standard screwdriver. If you can, it is probably box time...
Good hunting. You are working on a mid 80's 400 series stringer motor BTW...
