1 - 20 of 42 Posts
With so many great looking vintage jet boats on the market I'm starting to think outside the propeller box. My family is pretty into recreational skiing / boarding / footing, and all my experience is outboard, i/o, direct drive. What's it like on the end of a line behind a jet?
WFL Crew
depends on who's drivin!:D
its pretty cool :)...i pull almost everything behind my jet...the 1 thing u DONT have to worry about is some1 getting cut up by a prop, especially kids! :)
FastRat
I learned how to ski behind a jet
Just hit the gas and hang on:)sphss
Best to be behind a jet with a diverter:)bulb
and enough power to get them out of the water. my SBC had a real hard time getting a large skier out of the water. that was before the rebuild so maybe better now but it was real hard previously. Pulled a tube like a champ though.
in my experience someone that is pretty good on a single ski can pull the back end of the boat around pretty gd, a bit more than when you have a prop in the water. the wake behind my boat is decent size for wake boarding but maybe a tad big for slalom. Guess that would change depending on the hull type though. just my .02
Horsepower sells Engines
so my family has owned 5 jets including sea doo's (2), and own 1 prop (supra) the prop gets people out of the water better hands down, so my uncle says, he weighs 250+lb, but he likes footing and skiing behind the jet no prop wake, but most jets dont through a wake, so wakeboarding sucks, as well as to a lesser effect, knee boarding and tubing. plus i find pulling with the jet eats some fuel not saying they all do.
but a ski boat does not get the looks that my jet gets even when they have spent 100,000 cnd on it
Renegade jet
Depends on how much of a fanatic you are with your skiing. If you love slalom an make really hard cuts stick with an direct drive. A jet lays a pretty flat wake, but you can pull the ass around a little if you make hard cuts. I learned behind a jet and have had alot of fun skiing behind one. If the main thing you go boating for is water sports, I would get a direct drive. If you like to hotrod and boat in shallower rivers and just do watersports here and there for fun, definately get a jet.
its the sheet!
I learned to ski behind a jet without a diverter, and I must say that a typical jet makes alot shallower wake than a I/O and that makes for alot better cuting. I now own one with a diverter, and the down position makes planing out alot faster, so you can pull weenies on two skis alot slower.
There is also nothing that will make a quicker turn to go pick up a downed skier than a jet. Ask around, they turn on a dime compared to a prop if you know how. Another plus is that the kiddos dont have to worry about a prop chopping them up in the water.
Tubes are a blast behind a jet, you can sling around the serious riders like no prop boat can, and if you have a diverter you can play with it to change the wake or ever spray them a little. The kiddos can get a nice ride too if you just slow it down a little.
My personal opinion:A jet cant be beat as far as playing on the water, the only down sides are you can suck the rope into the intake if you arent paying atention and the average jet has less seating and storage than your average I/O.
Angry American
ditto all that! Back in the 80's, most everyone chose to ski behind my jet over a Ski Nautique and a MasterCraft just because the wake was a lot better to cut through.
The other semi downfall is if the ski tow is on the rear of the boat, it will get tugged around a lot more than a typical ski boat. The driver of the boat will need to be able to control the boat more than they would a ski boat or even a boat with an I/O. It's not all that big of a deal though.
one thing i notice a little between my sanger mini jet and my dads sanger mini v drive, is that my jet has a slightly bigger wake. (these are two identical boats with different propulsion) however the majority of jets are going to be smaller in size and have less v in the bottom then a ski boat, which is why the wakes are typically flatter as CAS said. The other thing i notice a little between mine and my dads boat is that inside the wake of a jet it can be very turbulent, i have always been used to it, but after skiing behind my dads v-drive it is a little nicer not having all the turbulence in the water.
Andrew
Wife, kids and friends have blast behind this. From skiing to tubing and also, we have had a professional wake boarder go behind this. He said, it puts out a awesome wake for wake boarding.
21 Daytona
Safety
One of the reasons I own a jet, we spend lots of time towing skiers,
tubes, kneeboards and even air chairs.
a good setup jet will pull the rope right out of your hands.
they have a very turbulent wake but only down the center, who ski's
in the center anyway. my last boat had a pylon mounted in front of the engine and that helped with the skier pulling the boat around.
most beginning skiers start out with at least a 75' rope and a diverter
helps a bunch.
Pink Taco
the best part
is after a long day of towing u go race some lake hot rod an he says how does a ski boat go that fast
Skied for many years behind a jet even shortened the rop at times too never a problem had great power for pulling up skiers.
now have an i/o it too does well just doesnt get me up as quick its only a 350 motor but doesnt struggle either.As far as wakes go they are about the same.
With so many great looking vintage jet boats on the market I'm starting to think outside the propeller box. My family is pretty into recreational skiing / boarding / footing, and all my experience is outboard, i/o, direct drive. What's it like on the end of a line behind a jet?[/QUOTE]
So much depends on the hull. The CP has a pretty small wake for a jet , but larger jets can have a hell of a wake. If you are an aggresive skier you can pull a smaller 20' jet around on "good cuts" so you may want to place the ski pole in front of the engine it helps a bunch. If the vintage jet is over 19' expect a good wake to jump.
S CP :D
I like skiing and tubing behind a jet. The wake is a bit turbulent in the center. But the wake is a LOT better to cross on a jet than an I/O, might not be as good for wake boarding because of that though. I don`t know how it is for barefooting, never tried to barefoot. I imagine the turbulence in the center of the wake might be annoying? But the quick start should be nice. Tubing works well too, don`t even notice the turbulence in the wake and the wake is still tall enough/well enough shaped to launch 1 tube and rider onto top of the 2nd/3rd tube/rider when you get the urge for demolition tubing:)devil.
What kinda prop boat is that? I have always had a much faster launch off a jet, pulls me from sitting in the water to fully standing in probably 4 feet.
1 - 20 of 42 Posts
