1 - 10 of 10 Posts
Gearing up to install BBC in my SST. I'm a little confused on how engines where rigged in these hulls.
I have all parts to do either a 3 point, 4 point, rail mount and even mercruiser type big threaded jobs with cast iron legs. Any suggestions and pix would be great.
Thanks-
Heck-that post was started by my kid, I just couldn't find it. He changed his user name. Thanks again.
stringers?
I believe it is a standard layup. I also believe these hulls have no actual stringers. Is there any truth to this?
they don't have stringers! people add stringers to them! my cousin just did an SST last winter, he chose to add them........
solid build
I figure that if hull was designed and built without stringers, then the structual integrity is in the lay up. It does have a deck/floor which I will be replacing. I bet the deck is one of the structual components. Any thoughts?
there is wood in the tunnels but I want to do stringers for the motor rails and 4 pt mounts, just putting the rails and pump brace made a difference feels stiffer
Looks like alot of work done from one pix to the next. Pump change? Tom JBP told me he actually make a kit for this hull. So the bolts go in from the bottom an "nutted" at the rails?
1 - 10 of 10 Posts
