1 - 5 of 5 Posts
I put a snipper on my blown 454 Sanger. I need some input on my problem. I’m new to efi and ok with a computer. My tune is a guess I would say because my 02 sensor is positioned wrong because the pipe is not long enough. I got dry bassetts. Does anyone have any ideas for me Please. Do I just turn off the learn and keep checking my plugs and hope it’s not to lean. All the snipper info is on cars not boats so I’m having a bit of trouble with building a timing chart so let me know if you can help me out I would appreciate it very much. Thanks
If its a Holley it should start within a range. I had an HP full MPEFI system and it was a real pain on a boat. I blew out O2 sensors and couldnt keep them from getting moisture. Eventually took it off.
You should have the ability to look at the data log. Do you have that?
Discussion Starter · #3 ·
Yes I do have data log and at idle it says it’s lean 28 to 1 but at high rpm when it isn’t allowing air into the pipe it runs 14/1!! I put a lot of hard earned money into my motor and can’t afford to blow it up. I think my best bet is to take it to a dyno tuner that does this for a living and can give me a conservative tune. Thanks for your input Sir
1 - 5 of 5 Posts
