For sale 21' Taylor jet boat 454 BBC
Could be made into a Clemson tigers themed boat very easily.
This is a Day Cruiser not a race boat engine was built to be fun and reliable it sounds awesome.
Complete restoration recently completed. Every part is new or rebuilt. Most parts are from CP performance Hardin marine.
This is what has been invested not including any of the hours and hours of labor !
Boat,engine and trailer paid 5,000
2 tone gelcoat with pinstripes, new floors. 3,200
New carpet. 250.00
New steering column. 450.00
New steering wheel. 200.00
New steering cable. 180.00
New reverse cable. 180.00
New front seats, pedestals, and mechanism
Seats slide and rotate. 1,400.00
Upholstery rear seat,side panels, sun deck. 425.00
Swim platform. 125.00
Stainless hardware every nut and bolt is stainless 300.00
Everything electrical is new
Wiring harness boat. 250.00
Wiring harness engine. 240.00
Livorsi gauges. 350.00
Fuel level senders (2) 60.00
Switches ,bezels, knobs. 150.00
Battery napa gold marine. 150.00
Battery box. 25.00
Auto bilge pump. 60.00
Bilge blower. 45.00
Starter napa. 150.00
Alternator ( marine) 280.00
Electronic distributor conversion. 200.00
Fuel system dual 20gal tanks
Stainless fuel vents. 40.00
Fuel filter with water separator. 80.00
Fuel lines and 3 Filters. 40.00
Fuel valve, left, right, off. 40.00
Foot pedal throttle. 150.00
Foot pedal throttle cable. 150.00
Engine and jet drive
Complete rebuild 454 BBC. 3,600.00
Cooling system is the best setup harden marine sells ! Thermostat housing has bypass to
The exhaust system. Water pressure regulator has a bypass to outside of boat it is set to 12psi.
Thermostat system. 170.00
Bypass valve. 125.00
Stainless discharge fitting. 30.00
All brass fittings and new hoses. 100.00
Glenwood exhaust manifolds. 400.00
Custom stainless Hardin exhaust tips 4" 350.00
Jet drive is a Dominator ( supposed to be better than a Berkley ? IDK) it has been completely rebuilt
By ARS marine ( advantage racing specialties) I have the receipt.
Jet rebuild. 1,370.00
New hydraulic place diverter system 1,300.00
New ride plate. 150.00
New steering rudder. 150.00
New drive shaft and u joints. 240.00
Trailer has 2 axles tires are good with spare, has bearing buddies.
Trailered the boat from northern michigan with no problem.
Trailer is setup for surge brakes but they need rebuilt do not work.
Just completed has not been in the water yet but will test as soon as time permits.
Over 20,000.00 invested I have SC title and new registration in hand.
18,500 O.B.O.
864-978- 9964. Text between 1:00 afternoon and 1:00 am
Located near Seneca Sc
