When building batt. cabels,what solder do you use for the ends?
Right,, never use acid core or soldering acid for electrical connections, it will corrode the wire.I use rosin core
X100Right,, never use acid core or soldering acid for electrical connections, it will corrode the wire.
For battery cables, you may have better results if you buy a tin of solder paste that you can dip the copper into prior to applying heat. You will find the solder flows quite a bit better than just trying to heat and apply the solder to the bare copper.
