Hi just replaced seals and strut bushings. Shaft is back in and want the correct spacing between shafts. thx also i guess the spacing between the prop and strut. thx in advance!
There should be no spacing between the output shaft and prop shaft. The coupler should have equal amounts of each shaft inside and two shafts should be butted up against each other.Hi just replaced seals and strut bushings. Shaft is back in and want the correct spacing between shafts. thx also i guess the spacing between the prop and strut. thx in advance!
