1 - 19 of 19 Posts
The carpet in the Nordic I just picked up needs to be replaced. I was thinking of removing the interior and having bedliner sprayed in.
Anyone have any thoughts of why not to do this? (BTW, the stringers and floor are in good shape)
....like warm apple pie
I would think that would add alot of weight to the hull. Isn't that stuff put on pretty thick? I personally would stick with carpet....its easy on the bare feet! ;)
"Try it Now!"
x2 on the carpet, but i have seen that stuff used in the bilge..looks pretty bitchin..plus i think they can color match it too.
Bed liner gets raeally hot on the feet in the sun where carpet tends to not get boiling.
I thought about this to but, I looked at bed of my truck and it started to look ashy. I dont know if there is a way to fix that, but I think it would look nicer and less work to go with carpet. just my .02
not too mention it will hide delamination & cracks. Carpet will too, but if you are smart about t putting the carpet in you can leave spaces unglued so you can do inspections later. Gel coat in the bilge works well and is easy enough to do.
I would go with carpet, but they do make all colors in bedliner material. Your gonna big $$$ for a different color.
I don't feel tardy
Bed liner belongs in a truck. :|err
If the need ever arises, you will play hell trying to remove that sprayed in bed liner.:)bulb;)
I would be concerned about the chemical effects on the fiberglass,and as stated above never see any delam. or stress cracks not good. Ever stand on bed liner barefooted:|err:|err Flow coat is another opp.
I have used it twice in two seperate boats and it worked great.... But not for a floor........
take off your shoes n socks n stand out in the street, you like that feeling ?
I dont..:D
two strokes is enough
my pops rhino lined his swim steps and everytime you get on them in the water i about eat chit its gets really slick when when so think it over before you do it
Discussion Starter · #15 ·
Fairly consistant opinions
I was thinking of a light color so it would be easier on the feet.
But being able to inspect the hull is important too.
Anybody just run bare fiber glass (meaning removing carpet and adhesive and leaving it) ?
I vote for bare fiberglass (treated) - since I have had much water in the bilge + an oil leak - the carpet absorbed the stuff that was kicked up by the flywheel (mixed water and oil). It's impossible to stand on this stuff now, so I have layed some car rubber mats temporarily on there now.
I like the carpet feeling but if you ever spray it with water + just a little oil, you can trash that carpet.
is that a bb boat?
A friend of ours has an old sanger hydro that had some major sponson damage along with filling about 120 holes with wood dowls. After the repairs he went out and sprayed in the bedliner stuff. I told him he was CRAZY especially since he runs this thing in the mid 140s!!! Just not the place for it!!! I know I'm a flat guy but all our boats just have the floors, no carpets, etc.. You could get some velcro that way it's easy to remove.
1 - 19 of 19 Posts
