1 - 10 of 10 Posts
Over the weekend i had the boat at the lake and came out sunday morning and noticed right by the fuel filler on the hull i am guessing some fuel sloshed out and got on the hull. Well now i have a nice little stain there are there any tricks to getting this out? If not what has to be done to get it out.
Thanks,
Cody
I don't feel tardy
Thanks,
Cody
What color is the gel?
What color is the stain?
What type of wax or polish do you use on the boat?
Sit N' Spin
I used to have some fuel stains on the side of my hull (white hull) right next to the fuel vents. I used Purple Power degreaser on it and it took it right out. Costs $3-$4 at any auto parts store and it's fiberglass/gelcoat friendly.
Sometimes a good cleaner wax will pul it out, but if the gel is not in so good of shape, it will penetrate into the gel and a wetsand will most likely be needed.
Discussion Starter · #5 · (Edited)
The part that the stain is on is white and grey. You dont notice it on the gray but is really shows on the white. I will try the purple power degreaser and if it doesnt work i will bite the bullet and have it wet sanded:)sphss Thanks for the info guys:D
have you tried rubbing compound?
I think meguier's has a stain remover. It has a slight grit to it, but not as harsh as sanding...it's been awhile since I've used it...
1 - 10 of 10 Posts
