1 - 20 of 35 Posts
Well, here I am at square 1 starting all over! Last run of last season finely got it running it's azz off and droped a valve!:mad: And as you all know had to built a new motor.:D Did an upgrade on motor and pump, changed the impelor going to give a AT HH a try!;) So it's back to the grind stone till I work out the kinks!
Motor is in and all new plumbimg done,wiring finished with a few added extras!:)devil pump is back and ready to install tonight! If all goes well I will be ready to hit the water Sat. or Sun. but the weather is not working with me!
Build is a 496 Pro Comp heads 10.1 comp Chris Straub cam profile dominator intake and Chuck Nuytton 850 carb. Produced 700 HP,700 Ftq ought to be fun ride!:D I was not looking for a race rocket but a sleeper creeper!:|err Scott Seastrum built pump and as I said a few extras!
I hope everyone has a good boating season and good luck with their projects! WT:)devil
Lookin' good Coby, Let me know how she runs on the water..
you already got it dyno'd coby?
Cajun Member
Hope the rain lets up for ya. Bullet looks shweet. I need to finish mine soon. 68 Camaro project got in the dam way.:|err
looks good good luck this go around:)devil
1 question why the high dollar hh impeller.:)bulb
Trying something different to see if it helps! Tested Sunday And man does it bite HARD! I set it a little tight and now got to get a little loosey! WT:)devil
Thanks Guys!
So how was the acceleration with the new engine? Did you get a MPH out of her yet?
Discussion Starter #12
It has got it! And then some. Got to do a little setup work and it will be flying! Sorry for the bad phone pic.
WT:)devil
not to bad!
Well, I am pulling the pump back apart and changing the impellor from an HH A to a HH B to see if I can get the RPMs up! The HH A is a biting BITCH:)grn over the old impellor! The 496 has no problems moving this boat from point a to b in a flash:D! We will later install a inducer if the cavitation problems persist!
As I said in starting this thread "Starting All Over" as always, one thing leads to another. THIS BOAT IS GOING TO WORK!!! We will try a few new tricks to see if anything helps or hurts and post it up! Later! WT:)devil
Question? Why are you adding an inducer if "she is a biting bitch"? What were you spinning the HH "A" to and what should the expectations of the HH "B" turn in comparison?
Im non induced and My turd leaves pretty hard as she sits.
You would not belive the difference from the Berk A, it was bad compared to the HH A. I am still trying to get the setup right! My RPM is to low for the motor 5000 when I need to turn 5700-5800 and oh yea the HH B might not do it could have to go to a standard B to get that RPM!
bronze aggressor ab would get r done:)grn
Discussion Starter #17
Tom, That might be it we will see! :D
somebody had a dps inducer in spam recently for sale cheap;)
Discussion Starter #19
I have got one located,and a few impellors and some shoes and,,,, then loaders you got any extras? :D WT:)devil
got a couple loaders, that about it, all the impellors i have got straight veins in em, put a bit too much hp to em:D
1 - 20 of 35 Posts
